Restricted Performance
Old Sep 16, 2021 | 09:22 AM
Oldman's Avatar
I've been getting the same issue on our 1998 XK8 for months. Performance is not degraded, but the message is annoying. Hadn't though of the MAF (I'll try that). Symptoms were the restricted performance light would come on when the car was hot, usually after hitting a rough bit in the road. I'm guessing it is the accelerator pedal (APP) sensor. By shooting a bit of electrical contact cleaner in the connection for the vacuum line on top of the APP, the problem would be gone for a few drives. Don't think the car is overheating, at least no obvious symptoms. Now that the weather is cooler, it isn't happened. Sadly, no longer have a big garage space and the extensive tools that once were there.... (sigh). However, the local Jag club has suggested a shop that knows these cars and as soon as it's time to take the car off the road, it'll go for a visit.
Old Sep 16, 2021 | 09:52 AM
Toolmaker's Avatar
Default Battery tender always
Originally Posted by Kuddlesworth
Very true but one is fun the other isn't. Think I spent about £350 on fuel. For my yearly holiday that isn't bad.
Buy a new mass flow sensor. Got a new one and it solved similar problems. Old one did not send codes . Best money I spent...
Old Jan 16, 2022 | 07:55 AM
Alan Byrne's Avatar
I've got the engine light on permanently, when I drive the car it's fine up to about 50 or 60 m.p.h. then restricted performance comes on which lasts between fifteen seconds and two or three minutes, then it turns itself off and is fine for the rest of the journey. No drop in performance that I can notice. I've changed the MAF, the o2 sense, fuel filter and throttle body. The only reading I get is P0171, running lean. Any ideas what could be causing this? Thanks.
Old Jan 16, 2022 | 08:53 AM
phobman's Avatar
Replace the MAF sensor connector!
Old Jan 16, 2022 | 04:20 PM
JagV8's Avatar
Check fuel trims - lots of threads to read
Moe Eid
Apr 2, 2021 07:40 AM
gkubrak
Apr 26, 2019 02:32 PM
DallasJagBoomer
Oct 15, 2018 09:24 AM
burmaz
Nov 23, 2010 03:39 AM
black vanden plas
Oct 22, 2010 11:34 AM
