Restricted Performance/Check Engine Light
Old Mar 19, 2025 | 11:09 AM
Jagsj's Avatar
Default Restricted Performance/Check Engine Light
Have replaced a couple of leaking air hoses, but so far does not fix issue of "intermittent restricted performance/constant check engine light" and I do not sense a change in performance while driving.
After each repair visit, will drive for 30 minutes, turn off, rest for 5 mins, restart, drive again, turn off, restart, then get the restricted performance/check engine light.
Mechanic getting "running lean" code, but about a year ago, it pulled code P0456, which is evap issue, I believe.
Should next move be to replace fuel filler cap?
I trust mechanic, and there is no one else available (dealership declines to help because of age of vehicle -- 2005 xkr convertible, 45k miles).
Just wandering in the desert !!
Old Mar 19, 2025 | 12:13 PM
dibbit's Avatar
Get an OBD dongle and the Torque app and read this thread to start with:-
https://www.jaguarforums.com/forum/x...ce-xkr-288284/
Old Mar 19, 2025 | 03:07 PM
JagV8's Avatar
Until you have the codes and when they occur (freeze frame data) you will probably not fix it but could spend lots of money guessing.
Old Mar 21, 2025 | 06:15 AM
Silverjag0's Avatar
Get decent obd tool
Old Apr 24, 2025 | 08:04 AM
Jagsj's Avatar
Issue now resolved -- by replacing MAF sensor and air filter !
Thank you for generous help !
Splash
Apr 26, 2026 04:46 PM
EscapedApe
Mar 10, 2026 10:24 AM
Jcbkwb
Sep 18, 2024 04:36 PM
omgimali
Oct 25, 2016 01:42 AM
Bob Aragosa
Aug 14, 2010 06:50 AM
