restricted performance message
Old Dec 14, 2012 | 08:59 AM
dennisw's Avatar
Default restricted performance message
just got this message on my car..used my code reader and its come up misfire on cyl 1.removed error.car starts ok the message back
any help please is it plug or coil?
now its p0351
a primary
Old Dec 14, 2012 | 09:32 AM
WhiteXKR's Avatar
now its p0351
a primary
Could be either, but coil failures are fairly common on 10 year old vehicles. Also make sure the spark plug well is not filled with oil or water. Oil means a valve cover seal leak, water means a coil cover seal leak.
Old Dec 14, 2012 | 08:25 PM
mike66's Avatar
You can swap coils with another cyl and see if the problem moves to the new cyl or stays with the original one.
magmedia
Aug 15, 2019 08:54 PM
X308XJR
May 20, 2019 06:50 PM
Old_Doc
Sep 29, 2015 03:43 PM
Collector1
Sep 28, 2015 03:52 AM
reb1999
Sep 26, 2015 08:41 AM
