Reverse park sensors not working
Old Jul 21, 2009 | 02:46 PM
jagpro69's Avatar
Default Reverse park sensors not working
My 2006 XK8 reverse parking sensors just stopped working. I checked the fuse and it was fine. Any advice?
Old Jul 22, 2009 | 06:13 PM
Fjk's Avatar
Fjk
I do not have the wiring Diag for an '06. But I am assuming it is the same as '04. IF that is true. The "Parking Aid Control Module" needs 12v and a line called "reverse lamps activated"s. Are your backup lights on when in reverse??
Old Jul 31, 2009 | 10:34 AM
jagpro69's Avatar
Default Reverse sensors
I haven't checked the rear lights yet. I have been reading about some of the problems others are having with the sensors. Mine make no noise at all. So I will assume its a module or speeker problem. Anyone know where the reverse park sensor module is located on a 2006 XK8?
Old Aug 10, 2009 | 10:01 AM
jagpro69's Avatar
I took it in to the Jaguar, still under warrenty. Told me it was a bad sensor.
Old Sep 7, 2012 | 06:18 AM
macbut999's Avatar
I am getting the 6 sec beep when the gearbox is 1st enagaged in R,my reverse lights are working and all the 4 sensors are sending out the clicking noise.So i can probably rule out sensor failure but still i get no noise indication when i reverse upto any type of obstruction.
Any ideas anyone
Old Sep 7, 2012 | 07:28 AM
WhiteXKR's Avatar
A clicking sensor is a useful test, but not a totally defintive indication that it is working, since the sensor is both a transmitter and receiver and the clicking only indicates it is transmitting.
That being said, you could also have a fault in your wiring, connectors or control module.
stanjag
Dec 29, 2024 08:26 PM
tberg
Sep 7, 2015 07:32 AM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
