Routing audio cable from trunk to centre console Jaguar 2000 model XKR Conv.
Old Feb 17, 2016 | 05:06 PM
Rocky15's Avatar
Default Routing audio cable from trunk to centre console Jaguar 2000 model XKR Conv.
I'm looking for the simplest method of routing audio cables from the trunk in my 2000 model XKR convertible to the centre console. I have the back seat (just the base) detached but cant see an easy route. There's a harness which is flat under the seat which splits in two and then goes to both sides of the car, maybe under the speakers but not sure.
I don't really want to dismantle anything more than I need to, so an easy option will be gratefully appreciated.
Old Feb 18, 2016 | 03:16 AM
jamdmyers's Avatar
you might check some post on hydraulic line replacement (convertible top), I've seen post with pics with the back seat backrest removed, it might help guide you.
Old Feb 18, 2016 | 03:28 AM
dibbit's Avatar
When I did mine, I took the rear seat back out and threaded the cables from the top right corner of the boot (as you look into it) through to the cabin. The hydraulic lines for the roof pass the same way. Of course, a 2000 might be completely different from a 2001 as we have found out.
I think you are going to have to bite the bullet and take that seat out - its pretty obvious what you need to do when it is out.
Old Feb 18, 2016 | 04:27 AM
Rocky15's Avatar
Many thanks
My hobby is turning into a nightmare.
dibbit I rewired everything for the phone kit. It was a nightmare as there was no phone connector in my armrest other than the one for the cradle.
After connecting everything my radio doesn't mute and my aerial don't go up (could be a coincidental fault)
Any ideas
Regards
Rocky15
Old Feb 19, 2016 | 03:21 AM
dibbit's Avatar
Well, on mine, one of the wires in the centre armrest console controls the electric aerial. Like many other people on here, I have installed a little switch in that wire to stop the aerial from going up. Maybe you disconnected it?
Old Feb 19, 2016 | 06:41 AM
Rocky15's Avatar
Many thanks
Will take a look but I also noticed my sat nav screen also doesn't come on so possibly I've disturbed something.
Forcedair1
Dec 7, 2017 10:39 PM
Eric.Desmond
Apr 17, 2016 04:55 AM
BenjaminA
Sep 7, 2012 06:01 PM
Gator8
Sep 23, 2011 11:50 PM
mplex2000
Audio/Visual Electronics
Jul 30, 2008 12:58 AM
