Runs rough after injector replacement?
Old Oct 14, 2017 | 04:53 PM
jobagadonuts's Avatar
Default Runs rough after injector replacement?
I recently had to replace an injector due to a warn O-ring. After replacing the injector the car still runs rough but not rough enough to put it into fail safe mode or throw a code. I replaced the replacement and it still runs rough. All electrical connections seem intact. Any ideas? Is it possible to have a single cylinder wash down?
Old Oct 14, 2017 | 05:12 PM
avern1's Avatar
I would think a single cylinder bore wash would be pretty unlikely plus after running bore was goes away. Have you checked to see what codes are showing up. It is possible while you were in there that you disturbed something causing a misfire elsewhere.
Read the codes and get back to us.
Old Oct 15, 2017 | 03:27 AM
joesoap's Avatar
How confident are you that the injector had a worn O ring?
What were symptoms before? are they the same or worse?
You need live data to tell what's happening, if it isnt setting codes.
Old Oct 15, 2017 | 06:43 AM
I agree with the previous replies suggesting something else has been the true cause of the rough running or been disturbed during the replacement.
As a procedure, I'd have done a hard reset to put the trims etc back to default after replacing a faulty injector.
Old Oct 15, 2017 | 01:22 PM
JagV8's Avatar
+1 on hard reset (to clear learned values, in particular the fuel trims and anything it keeps per cylinder/injector)
Then either let it relearn (some warm ups) or look closely at both LTFTs and STFTs to see what it's doing.
Old Oct 16, 2017 | 10:12 PM
It runs better the more I use it. I think maybe I fouled a plug. Going to pull it this weekend. Only code that shows is a generic p1000.
Old Oct 16, 2017 | 10:15 PM
The o-ring crumbled when I removed the injector. Most likely others are in the same shape, looking to replace all the injectors ASAP. It runs better the more I drive it. Perhaps I fouled a plug in the process.
Old Oct 17, 2017 | 02:34 AM
It's crying out for an 'Italian Tuneup'
Older members will nod sagely; the younger politically correct element will have no idea what this is and probably express the usual horror.
Old Oct 17, 2017 | 02:58 AM
JagV8's Avatar
Sounds like you're doing the right things. Keep an eye on that P1000 to make sure it eventually goes to P1111.
