Rusty sump
Hi again
My sump is leaking oil the side has rusted through I never thought I would see a oil filled sump rust, but hey this is a xk8, question bolts very small have sprayed with WD40 will they snap? Anyone help
The rust is from the outside Ivor, I had the same problem with an Astra van, a gob of some kind of metal repair paste fixed it right up for the rest of the time I owned it.
The only way to find out if the bolts will break is to try them.
I'd try a penetrating fluid other than WD40. My experience with it has been spotty, at best. Perhaps 'Liquid Wrench', or something similar.
If you remove the sump, it should be fairly simple to use a metal paste (in the U.S. we tend to use 'J-B Weld' - works a charm.
Andrew Fanshawe
Apr 4, 2017 12:51 PM
goges
Oct 5, 2015 04:53 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
