Rusty sump
Old Dec 15, 2014 | 02:40 PM
Ivor4ever's Avatar
Default Rusty sump
Hi again
My sump is leaking oil the side has rusted through I never thought I would see a oil filled sump rust, but hey this is a xk8, question bolts very small have sprayed with WD40 will they snap? Anyone help
Old Dec 15, 2014 | 02:54 PM
The rust is from the outside Ivor, I had the same problem with an Astra van, a gob of some kind of metal repair paste fixed it right up for the rest of the time I owned it.
The only way to find out if the bolts will break is to try them.
Old Dec 15, 2014 | 04:16 PM
Ivor4ever's Avatar
Cheers Norri tried metal glue almost stopped leak just dripping very slow,
Have got good 2ndhand pan will just keep spraying then hope studs come out
Thanks again.
Old Dec 15, 2014 | 04:27 PM
Jim D's Avatar
I'd try a penetrating fluid other than WD40. My experience with it has been spotty, at best. Perhaps 'Liquid Wrench', or something similar.
If you remove the sump, it should be fairly simple to use a metal paste (in the U.S. we tend to use 'J-B Weld' - works a charm.
Andrew Fanshawe
Apr 4, 2017 12:51 PM
goges
Oct 5, 2015 04:53 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
peterg19
Aug 28, 2015 08:42 AM
