SatNav the easy way
Old Jan 20, 2019 | 05:38 PM
nalle's Avatar
Default SatNav the easy way
Since I am cheap and lazy, I am trying this the easy way.. A simple hanger off the bottom edge of the vent, A Samsung Tablet with built in GPS, A cassette audio unit with a 3.5mm plug.
Now I can use any GPS Nav software I like - TomTom, Google, etc., etc.. Old ears don't hear so well anyway so the Cassette option works fine for me with all my music also on the Tablet. A USB charger in the cigarette light socket and I am set to go. I am trying it with 8' Samsung. If I like it, I will probably pick up a 7" and leave it there permanently.
Old Jan 20, 2019 | 07:00 PM
gjensen's Avatar
Only down side I see is if the heat is on. Might get the tablet a bit hot. Of course, you could direct the heat to somewhere other than those vents, I suppose.
Otherwise, it looks clean to me.
Cheers,
Gary
Old Jan 20, 2019 | 09:14 PM
John Nevets's Avatar
I'd be curious how it looks in the sun with the top down, but otherwise seems like a great solution. Also if you wear polarized sunglasses check to make sure you can still see the screen, I know mine sometimes give me trouble with my phone.
Old Jan 20, 2019 | 09:49 PM
nalle's Avatar
Cheers,
Gary
Been thinking about that. If I like the setuo after a bit of testing, I will probably get the smaller 7" Samsung to block the vents as little as possible. Might even turn it 90 deg and block the buttons instead?
Old Jan 20, 2019 | 09:51 PM
nalle's Avatar
Polarized are a problem. I use photo chromatic for driving and save the polarized for fishing.
Old Jan 20, 2019 | 10:15 PM
Johnken's Avatar
Great minds think alike - I used a gooseneck for same effect. Love it too.
Old Jan 21, 2019 | 06:57 AM
nalle's Avatar
Good looking option! I use Iphone a lot.. Great option for hearing aid wearers. Bluetooth straight to your ears. Only problem is when you have no cell phone signal, which seems to happen frequently to me. Therefore I wanted something with internal true GPS, downloadable maps and a slightly larger display. The Samsung has served me well in the Motorhome, where the display is further away.
Old Jan 21, 2019 | 09:05 AM
Barry_Tucker's Avatar
I use a Garmin sat nav simply because its does not suck up my phone data and I often travel to the US and UK so roaming charges are BAD....and I can take it with me to use in hire cars
My xk8 has the 3 gauge dash and I use the standard Garmin windscreen suction cup mount , which so far has worked perfectly for me
cacloss
24
Jan 29, 2024 05:01 AM
tdc
17
Apr 17, 2015 03:27 PM
yeeran
Jul 10, 2011 12:37 PM
nickpc2001
Mar 1, 2011 07:53 PM
nickpc2001
Feb 23, 2011 04:26 PM
