Scanner confusion
Old Apr 24, 2013 | 03:47 PM
rrosscoe's Avatar
Default Scanner confusion
Wonder if anybody has had a similar problem with any OBD scanner, I have a U581 hand held scanner which works fine on other vehicles (non Jaguar) now when I connect to my 2000MY XKR i do get readings but I also get "Electrical Fault" thrown up on the dash and may be coincidence but on one occasion my door mirrors stopped foldind/unfolding (after disconnecting battery and hard re set started to work again) so was wondering if it is damaging to use this scanner, Any one had this experience before ?
thanks
rrosscoe
Old Apr 24, 2013 | 04:49 PM
Vector's Avatar
Check the list here: https://www.jaguarforums.com/forum/g...oved-**-33347/.
I don't think your is on the list for our Jags. Not sure who makes your "U581" though.
Wasn't that a U boat in WWII? :-)
Non-compatible OBD scanners can throw "phantom codes."
Vector
Old Apr 25, 2013 | 07:21 AM
rrosscoe's Avatar
Default Memoscan U581
Sorry forgot to mention it is a MEMOSCAN number U581 sold by a company called UIF, it is the big brother to the U 488 as on the list of recomended scanners.
It does sort of work on the XKR but I am woried it may cause damage what with it throwing up Electrical Fault warning on dash, as the little brother works a would assume this one will be allright but its that warning I do not like,
Regards
rrosscoe
Old May 2, 2013 | 02:47 PM
rrosscoe's Avatar
Update,
Well have had car to local independant who has genuine Jaguar diagnostic equipment and guess what, his will not read the data stream either so looks like I may have a wiring problem. He like me can read and clear dtc's but as I said we can neither get live data from it, anybody had anything similar? have looked at wiring diagrams to see if there was anything obvious but no, as far as I can make out this is a CAN problem, am I right?
Regards
rrosscoe
Goncalo Proenca
May 3, 2026 01:36 AM
baskervillema
Oct 1, 2015 06:43 PM
mrplow58
Sep 30, 2015 08:56 AM
jjmiah217
Sep 28, 2015 09:09 AM
