Sealed Tranny
Old Feb 14, 2011 | 03:54 PM
Skid Mark's Avatar
I went by my indy shop, and the service rep pulled up Jag's instructions for replacing the tranny fluid. The oil change procedure described using a computer terminal (to run a CD disk) which is hooked up to the car while replacing the oil and cycling the gear selector. Do the instructions with these kits provide a way of doing it without the computer?
Old Feb 14, 2011 | 04:11 PM
WhiteXKR's Avatar
The only thing they are doing with that process is monitoring the internal temperature of the transmission fluid.
This can be done by measuring the case temperature of the transmission with an infrared thermomenter, or using a thermometer to check the fluid temperature a couple of times during the process through the fill plug.
If they have not done this before, I would find another indy.
Old Feb 14, 2011 | 08:12 PM
Skid Mark's Avatar
Thanks XKR, I'll make sure they understand that.
Old Feb 15, 2011 | 10:38 AM
H20boy's Avatar
If they plan on working on yours, and other jaguars, see if they wouldn't just want to purchase the AutoEnginuity scan tool with expansion pack, $500 or so...it reads all the car's internal sensors, including real-time tranny temp.
bdboyle
Sep 16, 2019 05:58 PM
Poet
Oct 2, 2015 09:00 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
millertic
Sep 30, 2015 08:11 PM
