Seat problem 01 xk8
Old Apr 30, 2022 | 01:17 PM
Rawxk8's Avatar
Default Seat problem 01 xk8
So, my left side driver seat quit as I was returning it to my regular position. I rarely move it and the auto seat isn't being used(either doesn't work and or not sure how to use it yet).
I was returning it back and it quit, no buttons work, I've checked every fuse I can find on the car. The fuse block on the left end of the dash 1 and 8 was fine.
I've switched the seat modules and they both work on the right side. Neither work on the left side.
I can get the seat out without taking the base out.
I think now I'm needing to test the seat controls or replace them. I don't know my options here or find a short in the harness, hopefully it's Isolated to the seat area.
Where y'all think I should go from here?
Old May 2, 2022 | 03:21 AM
PKWise's Avatar
The fact that you have lost all seat functions during adjustment suggests loss of power to the module. With your fuses OK then the next step is to confirm voltage supply to the module. The harness beneath the seat has a sort of 'S' bend where the copper can fatigue over time. A multi-meter could be used to determine voltage but I do not know exactly which pins on the connector will show the potential difference.
RC Tod
Jun 27, 2018 08:55 AM
stevepaa
Jul 14, 2017 07:26 PM
flyrr100
Mar 31, 2015 01:17 PM
bobk
Jul 16, 2010 06:41 AM
cooke
Jul 1, 2009 09:49 AM
