Seat will not move to the programmed position
Old Jan 13, 2011 | 11:14 PM
Linda's Jag's Avatar
Default Seat will not move to the programmed position
I have followed the owner's manual and programmed the seat. You position your seat, mirrors, steering column telescoping, and steering column tilt and then push "M" then the number (1 or 2). A "chirp" is heard showing that they are programmed. You then push and hold the number (1 or 2) until they reach their desired position. I set the seat then push "M" then "1" and I hear the chirp, but when I change the seat position then push and hold "1", the seat does not move. So, the system seems to program, but will not go to the programmed position. There is a switch on the steering column that reads "auto" and "off". It will not move to the programmed position in either mode.
Has anyone ever experienced this problem?
Old Jan 13, 2011 | 11:24 PM
H20boy's Avatar
double posting...tsk tsk
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
afterburner1
Dec 16, 2015 12:12 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
dcvickers
Sep 2, 2015 06:14 PM
