Seats wont go forward
Old Dec 6, 2023 | 01:48 PM
vinbee's Avatar
Default Seats wont go forward
The two front seats on my 1998 XKR won't go forwards. They will go backwards, which is odd and would suggest two motors - one for each direction and a separate power supply for each.
I tried to adjust the driver's seat to go forwards, to no avail. As I say, forwards was no problem. I then went to the passenger seat and had exactly the same problem. I was in the seat an hour earlier and had no problem adjusting it.
Any thoughts?
Old Dec 7, 2023 | 03:26 AM
PKWise's Avatar
The seat forward and backward motion is from the same motor, so your problem is electrical supply. I.e. Could be Switch/Plug/Cable/Module? Agree, it is very odd that your problem is on both seats.
Old Dec 7, 2023 | 05:31 AM
Rishi's Avatar
Pretty sure it’s the module. I had the same and it was the edge of the PCB which had a couple of the tracks
broken. Easy to fix if you are handy with a soldering iron.
Didn’t see it was both sides so that would be a coincidence if both modules failed at the same time!
Old Dec 7, 2023 | 05:57 PM
vinbee's Avatar
Default Thanks
Thanks for the advice. It appears to be an intermittent problem as this morning they both worked in both directions and then this evening the drivers seat wouldnt go backwards.
Are the seats easy to remove to get to the assembly that is shown in the photo?
I am very handy. I used to do a lot of electronics, building amplifiers, so would be straightforward for me to fix.
Old Dec 8, 2023 | 12:16 AM
Rishi's Avatar
As long as the seats are moving again it should be easy. Just 4 bolts and a few electrical connections. If it’s a convertible lower the roof as that makes it easier to get them out. They are surprisingly heavy!
Old Dec 8, 2023 | 03:14 AM
vinbee's Avatar
Default Seats
Thanks for your advice. Sadly, not a convertible but I am built like the proverbial outhouse, so wont be a problem lifting them.
c131frdave
Nov 13, 2023 01:50 PM
Rican
Sep 8, 2023 03:25 PM
oxendine
Apr 2, 2023 01:35 AM
AL NZ
Mar 29, 2015 04:12 AM
johnpreston84
Oct 27, 2012 08:24 PM
