Serial Data link quick question
Old Jul 24, 2020 | 08:37 AM
Johnken's Avatar
Default Serial Data link quick question
Yesterday Bob, Motorcarman, was kind enough to reference this diagram when I asked a question about my climate control module (AC Control module in diagram)
The cc's serial link is connected to the key transponder module and the Engine control module. Both of which work perfectly.
My question: can I conclude that since both of these modules work fine, the integrity of the serial network up to the AC control module is and must be working as designed?
Old Jul 24, 2020 | 09:20 AM
ccfulton's Avatar
It means that the wiring is not an issue downstream of connection FCS15 / 16.
It is still possible that the failure is with the wiring that goes to the Air Conditioning Module specifically although I would think it's a low probability because if if the wiring were damaged and it was shorted to ground or something like that, then it would interfere with the communication to the other modules as well.
Old Jul 24, 2020 | 09:26 AM
Johnken's Avatar
Thanks Charlie, that's what I thought.
John
Old Jul 24, 2020 | 11:41 AM
crbass's Avatar
Originally Posted by Johnken
...can I conclude that since both of these modules work fine, the integrity of the serial network up to the AC control module is and must be working as designed?
You know this other ways too, ECM and KTM work and are networked properly if the car turns on (I assume you likely do not have adaptive damping). Your mechanic's scan only didn't connect with the climate control module suggesting everything else is at least talking. Etc.
Old Jul 24, 2020 | 11:46 AM
Johnken's Avatar
Dale, Charlie,
GOOD NEWS, I hooked the new ac controller to the connectors, all works perfectly!!!
Thanks!!!
John
Old Jul 24, 2020 | 11:48 AM
crbass's Avatar
That's great!
Old Jul 24, 2020 | 12:07 PM
ccfulton's Avatar
Glad to hear you got it fixed.
Terrance39
May 29, 2020 11:05 PM
1927
May 20, 2018 11:18 AM
1999XK8
Aug 10, 2016 10:35 AM
03Xtype
May 16, 2016 09:57 PM
hafren
Aug 18, 2015 10:46 AM
