sidemarker clips
Old Oct 8, 2021 | 01:40 AM
buzzy1's Avatar
Question sidemarker clips
XK8 anyone know where to get the spring steel clips that hold the side markers in place? Or a part #? I found the markers without the clips, so I think they should/ or were available.
Old Oct 8, 2021 | 11:07 AM
bcprice36's Avatar
buzzy1,
Just go buy a Tube of "Clear" Silicone...Put it around the edges of the Side Marker and push it into place.....It will do the trick and will not show through.......
A Tube of Silicone cost about $8 to $9 Bucks.... It can be removed from the Fender if need be and will not damage the Paint.....or the Side Marker!
Billy Clyde @ Cinco Ranch
Old Oct 8, 2021 | 12:09 PM
buzzy1's Avatar
thnks, that is how it is on currently, just wanting to return to the clips. I found some spring steel strapping and made some. thanks for the time
Old Oct 8, 2021 | 01:24 PM
bcprice36's Avatar
buzzy1,
Then the only way to get the "Clips" would be to buy new Side Markers or go to a Wrecking Yard and get a Side Marker from a Wrecked XK8 or XKR....or spend the approximately $40.00 for a new one! Unless one of your Jaguar friends has an extra one to send you......
Maybe someone could help "Buzzy???
BC
Vee
Nov 2, 2018 08:02 PM
Andy W Nichols
May 9, 2018 05:14 PM
Jacsun
May 17, 2016 10:12 PM
wa3ra
Jun 11, 2015 08:16 PM
SRL1990
Sep 1, 2010 08:49 PM
