Smell in cabin
Old Jul 20, 2011 | 06:17 PM
Guiido9's Avatar
Default Smell in cabin
1999 xk8 convertable. Getting a fuel/exhast smell in cabin. Does not smell like raw fuel. Does not seem to come from under hood.Does have a little smell in trunk,but not as strong. Seems to do it after it is warm. (it has been 105 here lately, could be a factor)
Thanks, Joe
Old Jul 20, 2011 | 08:02 PM
hlgeorge's Avatar
Make sure your battery is vented properly.
Old Jul 21, 2011 | 12:15 AM
H20boy's Avatar
If you can't identify it as fuel...most can immediately be diagnosed as such i'd check the exhaust for leaks past the cat's. pinpointing the source (front 1/2 or rear 1/2 will lead you down totally different paths.
Old Jul 21, 2011 | 04:05 AM
Frog's Avatar
If it's a kind of burning oil smell, it could be the transmission. I had this under fairly harsh acceleration until I had the transmission oil & filter changed a couple of weeks ago. It now seems fine.
Old Jul 23, 2011 | 12:48 PM
kdross's Avatar
I have a 2000 xk8 with 48K miles, and I have a burning smell too. At first the problem was bad valve cover seals. But after I installed new seals, the smell came back. I think I may have a blow by problem and that is the source of the burning oil smell.
I would check for oil leaks first; especially around the valve cover. My car seems to suck in any smell from the engine compartment very easily. Hope this helps
Old Jul 25, 2011 | 12:08 PM
gchin's Avatar
A previous post explains about the different possible smells, but I remember that the owner identified where the smell was coming from. Then he changed either the fuel vent hose or canister.
LnrB
Oct 13, 2015 12:45 AM
NathanDD6
Oct 6, 2015 11:20 AM
mat32essex
Oct 3, 2015 04:12 PM
rgp
Oct 1, 2015 02:55 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
