Smoke after vacuum fix
Old May 5, 2023 | 07:04 PM
Dargam's Avatar
Default Exhaust Smoke after vacuum fix
Hi guys.
2003 XKR 4.2 70k miles.
After replacing the breathers o-rings and fixing some leaks including the intake tube, I started to get smoke on start up which smells like oil. Installed a new genuine PCV but the problem persists.
I am pulling a lot of oil from the PCV to the throttle, and this is also reflected by lower oil in dipstick. Also when I pull the hose from the PCV I have a huge amount of vacuum suction towards the intake from the hose at idle. Not sure if that is normal.
Only other thing that I did during the period was add fuel injector cleaner, which was consumed and refilled tank with new fresh fuel only.
Car drives great.
Fuel trims at idle are:
LTFT bank 1 = 9
LTFT bank 2 = 6
Fuel trims when driving:
LTFT bank 1 = -1
LTFT bank 2 = -3
Please advise.
Old May 15, 2023 | 03:27 PM
Dargam's Avatar
While waiting for some input, I will remove the cam/valve cover on driver side to check and clean the oil separator gauze as I read done by other members. Reason for this is when I pull the passenger side breather (the one connected to PCV) the suction to throttle is very strong, but when I remove the breather from driver side the suction to engine is very weak.
Fingers crossed.
G.M. Webster
Feb 20, 2023 09:33 AM
Norcat
Jul 5, 2022 09:14 AM
EsRay
Sep 9, 2019 09:55 AM
Dale Dunn
Mar 18, 2017 08:03 PM
nok
Jul 30, 2012 11:57 AM
