So, I’ve encountered clock/A-B odo memory issues
Old Apr 26, 2022 | 09:36 AM
Russell Gieselman's Avatar
Default So, I’ve encountered clock/A-B odo memory issues
My cat is a ‘97 XK8 convertible with 75K miles.
Replaced battery, battery cables and alternator last year. Alternator failure blew a couple fuses, all of which I’ve replaced.
My problem is this: the clock in the MIR and the A-B odo memory only work when the engine is running. Both worked properly prior to the alternator failure. The clock now stops once the ignition is turned off. Odo memory automatically resets to “0”. I checked and replaced all the fuses and relays that seem related to “ignition off” power to no avail.
Any ideas/assistance would be greatly appreciated! Thanks in advance.
— Russ
Old Apr 26, 2022 | 01:40 PM
Russ,
As you've already posted a separate Intro, I've moved your question from New Member Area - Intro a MUST to XK8/XKR forum. Members here with the same model will be able to help.
oo zone
Oct 8, 2021 02:33 PM
jackking jag
Apr 26, 2021 02:57 AM
01XK8
Sep 18, 2019 09:35 AM
BongoBilly
Jul 3, 2019 08:26 AM
P4nth4
Feb 18, 2010 06:04 AM
