soard don
Old Jan 25, 2021 | 06:19 PM
don soard's Avatar
Default soard don
New Jaquar project owner
Two weeks ago purchased a 1997 XK8 convertible, hasn't run since 2012.
Already having fun and love the help from the forums.
- Gas tank and Fuel Pump Replacement
- Rear Window Regulator replacement
- more to come I'm Sure
Live in Edmond Oklahoma
File Type: pdf
Old Jan 25, 2021 | 09:02 PM
Stuart S's Avatar
You're in the X150 Forum, for 2007-2015 aluminum XK/XKR models. Your 1997 XK8 is the previous X100 model and you should post your inquiries here:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Old Jan 26, 2021 | 05:59 AM
Bill Mack's Avatar
Don, whatever forum you should be in, you'll find experienced and helpful people ready to lend a thought, advice or caution. Good luck with you new project!
Old Jan 26, 2021 | 06:06 AM
Don,
I've moved your thread from X150 to X100 forum.
Old Jan 26, 2021 | 07:27 AM
SamtheSham's Avatar
Good luck with your project. You have found the best place for the best information.
Old Jan 26, 2021 | 10:06 AM
fmertz's Avatar
Just a quick heads-up. Before you start your new-to-you engine, be sure to double check the status of the secondary chain tensioners. This is THE major flaw of the early engines. Plastic was heavily involved in the original design (yes, plastic!). You need to upgrade to the third generation all-metal tensioner BEFORE you let these plastic parts ruin your day. If these fail, slack in the secondary chains lead to valves coming into contact with their respective pistons.
The new tensioners are available, somewhat affordable and installing them is within the reach of a determined home mechanic with hand tools (look up the zip tie method).
Best of luck, keep us posted.
Old Jan 26, 2021 | 02:42 PM
jagophile's Avatar
I admire the moderators who keep this forum sorted out. When I first arrived I had no clue there were so many mechanically dissimilar Jaguars. Moving the threads around seems to be a full time job.
remosusa
Mar 25, 2023 10:56 AM
1lowufoo
Aug 7, 2020 07:23 PM
randyb
Mar 23, 2016 02:00 PM
Bobman
Apr 12, 2015 10:59 PM
jeremys
Mar 28, 2015 10:33 AM
