Software/OBD2
Old Jun 29, 2014 | 11:17 AM
farmerwatts's Avatar
Default Software/OBD2
Just got my first XK8. I need software that can clear the codes on the transmission and read all other codes. Any suggestions?
Old Jun 29, 2014 | 01:06 PM
Welcome to the forum farmerwatts,
I've moved your question from XK/XKR 2006-Onwards to XK8/XKR 1996-2006 forum. Members here with the same model will be able to help.
This thread in General Tech Help will give you the combined wisdom on scan tools:
https://www.jaguarforums.com/forum/g...oved-**-33347/
Old Jun 29, 2014 | 03:42 PM
Jag#4's Avatar
here's a starting point: https://www.jaguarforums.com/forum/g...oved-**-33347/
Search the threads. Lots of info on various readers and scanners. You can spend anywhere from $20 to $1000 depending on how serious of a mechanic you are. I spent $39 after coupons on a Harbor Freight special and it does the job for me for basic codes and resets.
Not sure about transmission codes though.
Old Jun 29, 2014 | 04:11 PM
test point's Avatar
Reading codes is easy and cheap until you get into the codes beyond the standard set. For less than $20 you can get a OBDII data port to Bluetooth converter and an app for a smart phone or laptop computer. The TORQUE app for android phones is amazing. If you are asking about the extended code set for the transmission then the readers start at about $500.
Old Jun 30, 2014 | 02:24 PM
JagV8's Avatar
Mongoose JLR but be aware you can totally wreck your car's config so it won't start.
Old Jun 30, 2014 | 06:58 PM
test point's Avatar
JagV8,
Having trouble understanding your comment but none of the $500 and below devices will allow you to do anything that will negatively affect operation.
If you get into reprogramming that is a different tale.
Old Jul 1, 2014 | 09:22 AM
JagV8's Avatar
Sorry but you're wrong. Mongoose can be under $100
Old Jul 1, 2014 | 03:43 PM
test point's Avatar
Unfamiliar with Mongoose by Drew Tech I assume. Reading their web page it does appear that the device will permit reflash of auto computers with appropriate software. DrewTech Mongoose Vehicle Network Interface
Interesting . . . now is there any Jaguar reflash software out there?
Old Jul 1, 2014 | 04:34 PM
WhiteXKR's Avatar
Long read...but this thread will get you mostly caught up: https://www.jaguarforums.com/forum/g...an-tool-66558/
Old Jul 1, 2014 | 04:40 PM
WhiteXKR's Avatar
I know there are cheaper ways to go, but I think these on ebay: Jaguar Land Rover Diagnostics Coding Programming Kit Dealer Software IDS SDD JLR | eBay
are worth the few extra dollars. They resolder the adapter cables and pre-test them, plus the have pre-installed the software on a virtual machine saving long installation times and installation gotcha's.
Old Jul 1, 2014 | 06:43 PM
RJ237's Avatar
That's not expensive in itself, but I would have to sell my 97 and buy a newer car to use it. Too bad.
