Some thoughts on induction
Old Dec 9, 2014 | 05:51 PM
Gregfromuk's Avatar
Default Some thoughts on induction
This might be boring or may have even been talked about before but, here goes.
Why do people use metal or aluminium pipes for induction? They look pretty yes but surely these heat up and stay hoter for longer than plastic?
Also, has anyone thought about using heat shield wrap on the induction pipe? would this not ensure the air would have even less chance to heat up?
Old Dec 9, 2014 | 07:10 PM
cjd777's Avatar
Greg, I think you will find that the heated air has a greater reaction in the explosion inside the chambers. A cold engine does not run well, if you ever had a Triumph you would know.
Wayne
Old Dec 9, 2014 | 08:10 PM
Mikey's Avatar
It's a 'bling'/appearance issue only- nothing to do with performance. The air travelling through the pipe at WOT picks up a minuscule 1/4 of 1 degree F, irrespective of what material is used. Not worth worrying about.
Old Dec 10, 2014 | 03:23 AM
JagV8's Avatar
The Triumph issue is not relevant to our modern cars.
+1 it's mostly bling
BTW, On my STR a lot of it IS plastic and works fine...
Old Dec 10, 2014 | 04:54 PM
Gregfromuk's Avatar
Thanks guys :-)
clubairth1
30
Sep 3, 2025 04:38 PM
FrickenJag
Jun 16, 2025 02:15 PM
smartobject
Jul 6, 2016 05:28 PM
strippersteel
Sep 15, 2015 09:35 PM
tvholden
Sep 12, 2015 11:13 AM
