Sparking
2002 XK8 4.2 ltr. Developed slight miss fire at higher revs advised spark plug fault. So I'll change all 8 any recommendations for brand, type, ect?
Then move on to plug packs. Used Red tops in the Audi TT, worked much better at higher revs, should I go the same way with the XK?
Ron C.
Ron C.
Stock plugs work the best:
NGK IFR5N10
I can’t speak to any pros / cons regarding the coils mentioned
Z
edit: perhaps stock plugs are ND’s. I’m still sticking with the above NGK recommendation
NGK IFR5N10
Z
55chevy
Mar 15, 2018 07:07 AM
