Special tool . Gearbox level plug..photos
Old Mar 23, 2022 | 10:44 AM
Pistnbroke's Avatar
Default Special tool . Gearbox level plug..photos
Steve 1 gearbox 0 well after 1 hr fighting with bending 8mm bars and smashed 3/8 rachets I got out the welder
Big clout with a 4 lb bloc hammer and she is free.
One bash with a 4 LB hammer and the level plug on the gearbox is loose .. and the drain plug 4 bashes with the hammer .
Old Mar 30, 2022 | 05:31 PM
flylear45's Avatar
Attaboy. I may just start with one like that before even trying it without leverage.
Old Apr 6, 2022 | 01:24 AM
Pistnbroke's Avatar
Well worth doing I drained 3.6 q out and put 6 in !!! No grumble now.
Old Apr 6, 2022 | 06:23 PM
michaelh's Avatar
A bit OT, but I noticed that the box made a noise (best I can describe it as a moaning sound) when I was doing the drain/fill procedure at start-up with only the initial cold fill fluid level. Had me worried the first time I did it
Old Apr 7, 2022 | 01:10 AM
Pistnbroke's Avatar
I think its the pump fighting for fluid ..made a noise when going through the gears on the initial fill.....How did you go with the April fool or truth post ? Thought you might answer ? Maybe you didn't want to fall into the tappet trap !!
timskipper
May 16, 2021 10:41 AM
Yoosey
Dec 23, 2018 10:28 AM
Chris Steineger
XK120 XK140 XK150
Jun 29, 2018 04:10 PM
Will R
E type ( XK-E )
Oct 26, 2015 08:22 AM
TGK711
Mar 3, 2010 05:40 PM
