Speed sensor
Old Aug 25, 2018 | 07:30 PM
John Duffy's Avatar
Default Speed sensor
I removed the front wheels on my XK8, removed the bolts retaining the speed sensors, removed the wiring connector but I could not budge the speed sensors. Everything I have read just says 'remove speed sensor' but it was impossible. How do I get them out? I didn't bother trying the rear wheels.
Old Aug 26, 2018 | 12:31 AM
Johnken's Avatar
John, they just slide out. At least mine always did. I wonder what's binding yours. You did remove the hold down bolt right? As I recall it is 1 bolt per sensor.
if you missed it, no worries just let us know if you need help spotting it.
**edit- sorry John it was late, I see you pulled the bolt.
John
Old Aug 26, 2018 | 03:29 AM
dibbit's Avatar
The speed sensors probably haven't been moved for a decade or more - on my car they were stuck solid, but will come off eventually.
Old Aug 26, 2018 | 04:31 AM
John Duffy's Avatar
As said in the original post, I removed the bolts but the speed sensors would not budge. I tried to ease them out using a flat bladed knife, I gave them a dose of WD40 and left them for an hour and I tried to tap them from the other end using a very large screwdriver. Neither front sensor would come out.
Old Aug 26, 2018 | 10:12 AM
JagV8's Avatar
There are much better things than WD40!! (The clue is in its name.)
Old Aug 26, 2018 | 03:02 PM
zray's Avatar
Use the CRC brand of Freeze-Off. That will help any stubborn part relax its grip, especially a disc brake rotor.
Z
Old Aug 26, 2018 | 04:07 PM
oldmots's Avatar
The sensors can get road grit between them and the housing. Sticking a pressure washer nozzle in there should dislodge it. If that doesn't do it, you could try a strong solvent such as lacquer thinner to dissolve the crud.
JimC64
Sep 22, 2025 02:52 PM
Jagboi64
Oct 5, 2016 04:22 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Nov 1, 2009 12:51 PM
racerx82
Jul 18, 2007 09:50 PM
