stalled
Old May 22, 2013 | 01:28 PM
dodgerjames's Avatar
Default stalled
on journey and got stuck behind a lorry and nowhere to pass as my wife was with me going slow 30-40mph for about 15 min.then no response on pedal, engine stalled,pulled over, all dash lights on,turn key,starts and i pull away as if nothing had happened,i then put it in sports mode and drop the gears down and give it some wellie does not repeat for the last 15 miles home i usually drive a bit more aggressive than this,so is that the cause,or is there something i should worry about,there were no codes or anything on the dash
Old May 22, 2013 | 02:56 PM
ccfulton's Avatar
Something should be stored when the engine stalls, if nothing else I would expect there to be a freeze frame from the event.
Have you tried using a code reader to check if there are any stored or pending codes or data?
Old May 22, 2013 | 03:03 PM
thanks ,i will get the code reader out tomorrow and let you know
Old May 23, 2013 | 03:14 AM
not sure im looking in the right place but i cant see anything stored or otherwise
Old May 23, 2013 | 04:22 AM
No codes at all?
You must have at least P1000 (OnBoard tests not complete since last memory clear) or P1111 (OnBoard test complete).
Old May 23, 2013 | 05:29 AM
not doing something right,perhaps you could tell me how from the beginning,starting from diagnostic code
Old May 23, 2013 | 06:31 AM
steveinfrance's Avatar
What code reader are you using ?
Old May 23, 2013 | 06:35 AM
actron
Old May 23, 2013 | 07:07 AM
Well, as Graham says, if you're not seeing a P1000/P1111 it ain't working.
Is it telling you it has connected?
Old May 23, 2013 | 08:30 AM
i have the p1111 one but there is nothing else,but having said that i dont know what i am looking for
Old May 23, 2013 | 08:45 AM
If there's just the P1111 then no other codes are set.
Simple answer - replace wife with code reader on future journeys then if it happens again you'll see a code come up.
Old May 23, 2013 | 09:11 AM
wife not too pleased with that last remark as she doesnt drive
Old May 23, 2013 | 09:37 AM
Originally Posted by steveinfrance
................. Simple answer - replace wife with code reader on future journeys then if it happens again you'll see a code come up.
Please post full details of this trade-in deal for a code reader.
Old May 23, 2013 | 09:41 AM
Haven't you got AutoEnginuity ?
Wife on Eurostar, please meet at station.
You've got my address for the carrier.
OP's wife will simply have to cradle the scanner in a loving and attentive way at all times then.
Old May 23, 2013 | 10:17 AM
thanks for the info and for cheering up my wife
Old May 24, 2013 | 07:46 AM
Seriously if there are no stored codes I'd put it down to 'one of them things', keep your reader in the car and not worry.
Let us know if you have another wobbler.
Old May 24, 2013 | 08:16 AM
WhiteXKR's Avatar
+1. See if it happens again. Even the best designed electronics could be occasionally susceptible to soft errors from electromagnetic interference, atmospheric radiation and other random occurances.
I have had a MB C320 since new for 11 years. Once, at about 30K miles the electronics went totally bonkers, all dash lights and warnings flashing, car about to stall. I now have 140K on it and that had never recurred.
Old May 24, 2013 | 08:58 AM
I had a non-Jaguar stopped in its tracks by something the Royal Radar Establishment were doing. Driving past their place it stopped dead and sat with the door locks cycling on and off every two seconds.
Most weird and uncanny.
I'm surprised modern cars don't get glitches more frequently.
Old May 24, 2013 | 11:31 AM
i had a 3l rover 30 years ago and that use to happen to me every time i passed the m.o.d. establishment on top of portsmouth a.s.w.e.
Old May 27, 2013 | 09:13 AM
Galmann's Avatar
Default engine stalled
Same happed to me yesterday.
stalled, turned key off then on again fired up,no codes .
hopefully never again ,but could happen ,and create a dangerous situation.
hope anyone who figur out anything will follow up this thread .
Best Galmann
