starting issues plz help
Old Apr 9, 2012 | 09:31 PM
mikeeadyjr's Avatar
Angry starting issues plz help
symptom: tuning over wont start
already check:
fuel pump
the spark plug (only one) it look like it may need to be change but its still had a strong spark
took the battery to (AZ) and they tested and its good
I drove it to work about a hour or 2 later went to leave started it up then it shut right off like it choke out or something.
Solution: took the car to the dealer and they replaced the fuel pump and fuel regulator.
Old Apr 10, 2012 | 03:41 AM
Gus put together a non-start troubleshooting sequence. It's on his website:
JagRepair.com - Jaguar Repair Information Resource
Start with reading the codes. This should indicate what the 'something' was that caused it to shut down after starting.
Old Apr 10, 2012 | 06:30 PM
mikeeadyjr's Avatar
Is a possibility that it could be flooded out
Old Apr 10, 2012 | 06:43 PM
WhiteXKR's Avatar
You should read the codes...that may narrow down the problem.
Old Apr 10, 2012 | 08:10 PM
mikeeadyjr's Avatar
i dont have a code scanner i also look in the throttle body and and it was full of fuel
Old Apr 10, 2012 | 08:16 PM
mikeeadyjr's Avatar
i suck out four soda bottles of fuel out the throttle body
Old Jun 14, 2012 | 06:07 PM
mikeeadyjr's Avatar
fixed 1500 later. fuel pump and fuel regulator
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
Raul Lara
Sep 14, 2015 07:31 PM
Jjscruggs1
Sep 3, 2015 07:46 PM
obwoodie
Sep 3, 2015 07:45 PM
