Steering Wheel
Old Sep 28, 2025 | 07:42 AM
sanchez's Avatar
Default Steering Wheel
Another issue: the telescoping feature on my steering wheel does not work. When I use the switch the up/down tilt feature works, but no response from the switch for the telescoping feature. I do not hear the hum of the motor working at all. Is there a way to check this without having to dismantle the steering column to expose the motor? I am still doing research on this but I am still throwing it out there.
Old Sep 28, 2025 | 08:24 AM
motorcarman's Avatar
The reach cable is broken.
Common fault.
Search for REACH CABLE BROKEN
Old Sep 28, 2025 | 10:13 AM
sanchez's Avatar
I have looked at "REACH CABLE BROKEN". However, if the cable is broken, wouldn't the reach cable motor still work? As stated, I do not hear the motor humming. If the reach cable is broken will that stop the motor from working?
Old Sep 28, 2025 | 10:49 AM
The motor could fail.
The most common fault is the cable but make sure the motor is plugged in.
The connector is a YELLOW 8 way.(FC61 / 8-WAY MULTILOCK 070 / YELLOW)
Old Sep 28, 2025 | 11:12 AM
kstevusa's Avatar
You may consider the motor is at end of travel limit and will only activate when reset. That is the reason the DVOM reading is used to set it during operating cycle.
Old Sep 28, 2025 | 06:37 PM
sanchez's Avatar
I haven't done anything with it yet as I am still trying to learn how the system operates. I don't want to go in there without at least a basic knowledge of how it works, so it's back to school for me while I study this. I am not going to touch it until I fully understand how it works. I hate having to do a job twice or make a stupid mistake.. I have the steering wheel and front seats out of the car to get them upholstered so I think its best to fix this before I put them back in the car.
Stypejag81778
Aug 31, 2021 02:39 PM
Saki
Feb 24, 2020 08:45 PM
Bcrary3
Aug 18, 2015 09:06 PM
cybercg
Jun 29, 2015 07:23 PM
tbDallas
Dec 3, 2011 07:16 PM
