Steering wheel vibration
Old Sep 10, 2009 | 07:30 PM
test point's Avatar
Welcome to the forum! ! !
The most obvious issue is tire pressure and brand of tires. These cars are sensitive. You can't discuss such things where they can hear.
Earlier cars had a history of front end bushings and shock bushings problems but by '02 they were much better.
How many miles?
Any abnormal tire wear?
Any 'clunks' involved?
Old Sep 10, 2009 | 08:45 PM
Robscountach's Avatar
Also, If you've got 19"s like me, you'll feel most everything. Just ensure the tire pressures are correct (when cold).
Old Sep 12, 2009 | 01:47 PM
H20boy's Avatar
Welcome to the forums bob.
I have 19s, and as the tires age, the steering wheel will feel more of the road cracks and bumps...its the nature of these cars. Although my car has always had this 'feel' (first thing my mom told me after driving it for the first time...compared to her Lincoln, and trust me, i've had lots of suspension work done in the front), the newer the tires, the less vibration being transmitted to the wheel.
My tire pressures have fallen since I've had the first set of tires, and over 25,000 miles ago... 32 front, 29 rear.
My dealer service guy told me if I wanted more absorption of these bumps, I could drop the front tire pressure more, but since the inner tire wear is already greater than the center and outer areas, any less pressure would only exaggerate this condition...no thanks. Tires are expensive.
I run 30psi all around.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
hen555
Sep 7, 2015 11:13 PM
