Stereo won't play through speakers 1999 xk8 conv
Old Aug 26, 2013 | 12:26 PM
Anvil's Avatar
Default Stereo won't play through speakers 1999 xk8 conv
The volume (deck shows everything working properly) will not play through speakers. I have tried everything stated here on radio issues without removing anything. When I press am/fm and eject together then mix and eject it says divers off. A kid was playing in car just before this happened
Old Aug 26, 2013 | 01:23 PM
Jag#4's Avatar
Make sure your settings (Bass, treble, woofer, etc.) are OK. If these are turned down, it could be your problem.
Old Aug 26, 2013 | 01:58 PM
DaveC's Avatar
+1 on the setings. If they are good see if your power antenna goes up when you turn on the radio. If it doesn't go up the fuse may be blown. The antenna and power amplifier share the same circuit on the MY99. The head unit still lights up but no sound. fuse is in the trunk.
Old Aug 26, 2013 | 02:31 PM
Anvil's Avatar
Default Thanks
Thanks. My antenna goes up and down and I have adjusted my +/- features to no avail
Old Aug 26, 2013 | 02:33 PM
jimbov8's Avatar
Try a hard reset, may just do the trick.
Old Aug 26, 2013 | 03:00 PM
Anvil's Avatar
How does one do a hard reset?
Old Aug 26, 2013 | 04:45 PM
Jag#4's Avatar
From the DIY sticky on the main page.
https://www.jaguarforums.com/forum/x...ect-faq-74146/
Most US cars do not need the radio reset (maybe early models?), but the personal settings for bass, treble, etc. will need to be reset. And certainly the windows on convertibles. Hard to tell what you need without knowing model and year of your car.
Old Aug 26, 2013 | 05:27 PM
Anvil's Avatar
Default Got stereo to play for 15 seconds then static
I pushed 5 buttons on the stereo and sound played for about 15 seconds with increasing static, then kicked on and off a couple times then stopped. I can get it to do it over and over. So I think I just have to invent a 5 finger pushing instrument and I will be set. Is there a website for that? Or maybe a better solution? Thanks
Old Aug 28, 2017 | 07:04 AM
mdiamond's Avatar
Anvil, if you check out the fix I posted, No Audio, Stereo, 1999 XK8, you have exactly the same problem that I had. the fix is easy, and does not cost anything.
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
