Sticky Ignition Switch
Old Nov 8, 2013 | 09:35 AM
berlin1977's Avatar
Default Sticky Ignition Switch
Good morning, I am having some issues with my Igintion switch. When removing the key steering wheel will not retract and go to the up position. I can tap the key on the key slot and it will function properly. I think it just needs to be lubed. Should I try silicon or grafight? Concerned about silicon causing an issue with the electronics and grafight gumming up the switch. Any input would be appreciated. Thanks Jim
Last edited by GGG; Nov 8, 2013 at 09:54 AM. Reason: edit typo in thread title so it appears in searches
Old Nov 8, 2013 | 09:52 AM
XKRacer's Avatar
There is a little "door" that covers the key hole, it is this that is sticking so the car thinks the key is still in the ignition, I just use a simple squirt of WD40 does the trick just as well
Old Nov 8, 2013 | 09:54 AM
berlin1977's Avatar
That the problem area. Thanks jim
Old Nov 8, 2013 | 09:57 AM
Originally Posted by berlin1977
............ I think it just needs to be lubed. Should I try silicon or grafight?
Locksmith's graphite is the best product for lock lube.
It doesn't pick up dirt or dry out.
Old Nov 8, 2013 | 10:04 AM
berlin1977's Avatar
dsnyder586
Dec 29, 2024 07:39 PM
kurtomatic
Sep 26, 2015 10:31 PM
Johnken
Sep 22, 2015 03:53 PM
dstary
Sep 19, 2015 09:47 AM
1964Daimler
Sep 9, 2015 11:28 AM
