Still Coding but running better
Old Apr 25, 2011 | 06:29 PM
zmann96's Avatar
Default Still Coding but running better
Hi Guys,
Well, It was coding #2 originally ( restricted Performance) . I put a new coil in #4 cylinder. I had switched #2 with #4 and it followed to #4. I've been running it and it's weird, it won't code right away but after about 20 - 30 minutes it codes restricted performance for about 5-10 minutes and then it clears. runs fine for for a while and then codes again and goes out. Today I read the codes again and now it's coding #1. I'll list the codes I have after driving for a week. I had cleared the codes about two weeks ago.
P0301 Cyl # 1 Misfire
P1313 Ignition System or misfire.
P1316 " " " " not sure why different code for same???
P0351 Ignition Coil A Primary/Secondary circuit malfunction
P1000 Control fuel/air emission controls.
I'm not sure what to do next. All new plugs, no oil was in the plug wells
Old Apr 28, 2011 | 04:26 AM
zmann96's Avatar
Hi Guys, does anyone know what may be going on.
Old Apr 28, 2011 | 07:37 PM
hlgeorge's Avatar
Check the connectors on the coils. May have an intermittent connection.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
nitrolouie2142
Sep 5, 2015 01:55 PM
