Strange click noise from idle and up
Old May 9, 2012 | 01:59 PM
Miramar2's Avatar
Question Strange click noise from idle and up
Dear all,
My name is Tom and i live in Norway. Yesterday i bought my self an 1998 XK8 4.0 V8, that i like a lot. It has only done 71000 Km, and has a full service history.
I had a good look around this fine forum and learned a lot already.
However, i have noticed a "click" (just one) from the front of the engine when rewing up from idle. When i release the throttle again, i can hear the same click again. This happens around approx. 1000-1100 rpm and with warm engine. No other noises abnormal noised can be noticed though.
Inside the car, i can barly hear it.
Do anyone of you fine Jag owners have any tips in this matter.
Thank you in advance
Old May 9, 2012 | 03:34 PM
cohibarandy's Avatar
Mine does it also. . An '05 xkr. I've heard others do the same. I believe it is a simple expansion in the exhaust. It does it when the engine is shut off and still hot as well.
Old May 9, 2012 | 03:58 PM
XKRacer's Avatar
You will probably find that is the sound of your VVt solenoids engaging and disengaging, does it around 1300 rpm
Old May 9, 2012 | 10:39 PM
H20boy's Avatar
does it fall and rise with RPMs as well? if so, +1 to xkracer's wisdom
Old May 10, 2012 | 12:54 AM
Miramar2's Avatar
Thank you all for good advices!
I am convinced that Xkracer has pointed out the cause to the "click".
No problem to own a Jag when there's so mutch skilled people around here.
Once again, thank you all
Old May 10, 2012 | 02:16 AM
XKRacer's Avatar
Not a problem but you can check it... On the front of the heads you will see a round object with a electrical cable/connector coming from it, put the tips of your fingers on it and rev the engine, you will feel it click as well as hear it
Old May 11, 2012 | 02:21 AM
Miramar2's Avatar
The "click" sound has now been confirmed to be the VVT solenoids (thank you XKRacer). I was first a bit scared regarding the well known chain tensioner issue. Fortunatly, yesterday i checked with the Jaguar dealer in Germany who has done the previous maintenance on the vehicle, and they confirmed that all tensioners and chain guides has been replaced. Lucky me :-)
Old May 11, 2012 | 02:43 AM
steveinfrance's Avatar
Here's a longer thread on the problem
https://www.jaguarforums.com/forum/x...lenoids-26827/
I do go on about this but always try a Google search for your problem rather than use the site engine. I put 'Ticking XK VVT' in and got this as the first hit.
I knw you didn't know it was the VVT at first but it's a useful way of getting more info.
Good luck!
Old May 11, 2012 | 03:43 AM
Miramar2's Avatar
Hi Steve,
Thank you for your information. I have already been into this thread, but to me the thread seems to concern "ticking noise". However, i do only have one "click" when idling up, and then one "click" on retarding. At first i was afraid that it may be caused by "slack" (excessive play) in the cam chain(s). Fortunatly it's not.
flyrr100
Mar 14, 2016 06:37 AM
Mac Allan
Oct 27, 2015 04:49 AM
santer
Sep 25, 2015 03:28 PM
JagBrian
Sep 21, 2015 07:17 PM
raulan
Sep 10, 2015 12:43 PM
