Strange Door Lock Problem
Old Mar 19, 2015 | 05:51 PM
Kitty Paws's Avatar
Default Strange Door Lock Problem
Just today, Kitty started acting very, very strange. When I tried to lock the car at a shopping stop, I used the button on the remote standing right next to the car. I hear a beep sound, (not the horn) and then the door locks cycle like 3-4 times and remain unlocked on the driver's door only. Seems the passenger side locks after the cycles.
I tried cycling the convertible top down then up until the chimes sound - no difference.
Also, the key will not lock the door manually when inserted into the door.
I cannot manually lock the driver's door from the inside either.
I remember older cars had a button thing that would turn off the dome light, etc. Maybe our cars have one and it is stuck or broken?
Any suggestions where to start?
Old Mar 19, 2015 | 08:47 PM
Johnken's Avatar
I've had strange stuff like this with door locks when the battery got a bit low. Try a charge then I hope it solves it for you.
Old Mar 19, 2015 | 09:10 PM
WhiteXKR's Avatar
And if not, it is likely a bad microswitch in the door latch mechanism.
Old Mar 20, 2015 | 02:38 AM
B o B's Avatar
I had exactly the same problem. New door lock mechanism fixed it.
Old Mar 25, 2015 | 06:43 AM
oyster's Avatar
Kitty Paws.
Have you solved your problem? I have posted a new thread with a somewhat similar problem.
99xk8guy
Sep 29, 2025 10:51 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Raul Lara
Sep 14, 2015 07:31 PM
obwoodie
Sep 3, 2015 07:45 PM
Raul Lara
Sep 2, 2015 05:23 PM
