Strange electrical
Old Jan 20, 2018 | 03:23 PM
larueb's Avatar
Default Strange electrical
Looked at a 2000 today with 89,000 miles and one owner. I think the interior had gotten wet as the carpets were wet and radio seemed to show moisture. Strange part was both seats did not move, radio dead, climate controlled worked but fan would not come on, wipers did not work, trunk and fuel door did not release and top would not go down as Windows would not drop.
any ideas? A single issue of a module or multiple issues. Great price but.....
thanks.
Old Jan 20, 2018 | 03:34 PM
franksm's Avatar
That is the Body Processor Module (BPM), it controls all of that plus lights plus mirrors etc.
Could be a couple of fuses blown if the carpet is wet but needs checked. The BPM is up above the glovebox. Was the car in a flood, I wonder...
Do check the fuses though...
Old Jan 20, 2018 | 03:43 PM
Lady Penelope's Avatar
https://www.jaguarforums.com/forum/x...esolved-80126/
There is one king relay that controls each box of fuses . Put your finger on the relay and feel if it gets it's commanded click closed from the key switch rotated to on before start detent .
http://www.jagrepair.com/images/Auto.../jagxk2000.pdf
See the pic with the circled king relays :
Old Jan 20, 2018 | 06:38 PM
RJ237's Avatar
Sounds to me like a flood car.
Old Jan 20, 2018 | 06:44 PM
avern1's Avatar
Definitely sounds like the cars been in a flood. Another problem area will be the SCLM (security module) It is mounted under the fuse box in the trunk and it will not let you into fuel/trunk if it is wet and corroded.
Scott Taylor
Jun 17, 2014 01:17 PM
XJ8JR
Sep 27, 2013 04:18 PM
jeffmartinaz
May 22, 2013 11:36 PM
regal
Feb 16, 2012 03:18 PM
topherscott
Oct 8, 2011 08:12 PM
