Supercharger removal 2006 XKR (X100)
I'm removing my supercharger to get at a fuel leak on my fuel rail. I am stuck at the induction elbow below the throttle body. All of the bolts are out the hose clamps to the intercooler are loose, but it is just not coming out. Any tips or tricks to remove it would be appreciated.
Several threads on this forum discuss this not too uncommon issue. The preferred fix by many is to remove the dampers and seal-weld the openings. Not a cheap job (unless you're best buddies with a highly qualified welder), but comically expensive replacement dampers have been known to start leaking not very long after the supercharger was reinstalled. Not a risk I wanted to take, so I had mine welded.
LausDeMaus
Sep 5, 2022 07:25 AM
