Surprise!! - Bad oil pan discovery
Old Nov 4, 2014 | 06:08 PM
RJ237's Avatar
Nickel is magnetic, but I have no idea how much is deposited or whether it's in metallic form. If you have liners I would expect a visible seam.
Old Nov 4, 2014 | 06:37 PM
TC Johnson's Avatar
That is what I wondered, since there is no visible seam for liners. That Nikasil must be plen hard, since all the clag is on the pistons and not on the cylinder walls.
Other than possibly having the pistons knurled and machined to spec, a clean set of pistons seems to be my option.
TC
Old Nov 4, 2014 | 08:58 PM
Chuck Schexnayder's Avatar
Thanks Norri,
Just got tired of the little waving dude. May use smilies again--if I find one not so irritating. Thanks again.
Chuck
05/XK8
Old Nov 4, 2014 | 10:52 PM
scardini1's Avatar
With regards to my bearing failures: I think there's a chance that with the extra quart or so added to the 4.2 there's a chance that over filling led to foaming which caused the failure. As I understand it, when Jaguar raised the capacity of the engine all they did was change the dip stick markings so there's less room for error on over filling. With that in mind, my new engine never gets more oil than center on the dip stick. However, this is just a theory of mine, with little evidence to back it up.
Old Nov 5, 2014 | 07:17 AM
The Coupe's Avatar
Possible, I suppose, but the engine design does include a "windage tray." From the original Jag technical document on the engine design:
"A windage tray attached to the top of the structural sump isolates the oil pan from the disturbed air produced by the rotation of the crankshaft, to prevent oil aeration and improve oil drainage."
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
Dymaxxion
Sep 4, 2015 02:40 PM
