Suspension fault after replacing front shocks
Old Apr 25, 2018 | 09:15 PM
baguafit's Avatar
Originally Posted by Jon89
I have not darkened the door of Jaguar Cary (formerly Leith Jaguar) in years. They simply do not have the master techs who know our older vehicles and have the experience to work on them properly. Like most Jaguar dealerships these days, they are staffed and geared for the Tata-era vehicles. Jaguar Greensboro still has a couple of master techs with more than 30 years of experience (Nhao Haboon and Georgiy Koshelev) and on the rare occasions when I need a dealership's assistance, that is where I go. Nhao and Georgiy make it well worth the drive....
The best local Jaguar indie shop in our area is Flying Circus English Cars in Durham, owned by Toby Briggs. Toby is one of the kindest, most knowledgeable British car enthusiasts I have ever met. He has given me free advice over the phone many times during the past six or seven years and whenever I reach my DIY limit on a repair that stumps me on either of our Jaguars, I take them to him. His prices are very fair and he will take the time to explain to you exactly what he found and the various courses of action that you should consider....
Call him at (919) 596-4250. His customer service skills and diagnostic capabilities for our older Jaguars blow Jaguar Cary away....
Thank you Jon89. Toby sounds like an excellent resource. Hadn't heard of Flying Circus before -- wish I had!
Old Apr 26, 2018 | 04:16 AM
toaster's Avatar
I would give it a try.
Old Apr 30, 2018 | 05:02 PM
baguafit's Avatar
Well good news is the suspension fault is off. Bad news is I don't definitely have an explanation as to what happened.
Removed the right rear shock to find that both wires had been cut and the wires looked like someone put them into a drill and spun them really tight. Perhaps the wires broke but sure look like a clean cut on both. After repairing the wiring, the suspension fault is gone. I cannot read the diagnostic codes so not sure if the front shocks are still faulting but at least the car is not riding in default/firm mode and the fault warning is not appearing on the dash.
I've been mulling over how to explain this and am at a loss. Only thing that I could imagine is that the suspension fault did not come on with only 1 of 4 shocks showing open circuit, but when I disconnected front shocks that tripped the fault and DTC or module were never happy again until I closed circuits on all 4 shocks. Doesn't totally make sense because I did a hard reset after 3 of 4 shocks were closed circuit and still had the fault...so there must be more to this. I have no idea about the right rear wire twist and cut...I don't see how the shock piston could have rotated over time winding the wires but maybe that's a possibility.
I've very thankful for all the advice on this and wish the picture was clearer to help someone else down the road.
Old May 6, 2018 | 02:14 PM
dgr's Avatar
dgr
Default Question on coil springs/shocks
Hi Baguafit,
I've got the same occasional bottoming out on my 2000 XKR. Was the coil spring replacement alone able to cure the problem? What was the cost if I may ask? I don't have any suspension faults.
Thanks!
DGR
Old Jun 11, 2018 | 04:37 PM
baguafit's Avatar
Hi DGR -- sorry didn't see your comment until now. Yes, the problem was the coil springs were spent which I understand is fairly common and will get worse in time. Contributing to bottoming out was the rubber bumpers had rotted and fallen out. I've heard some say to just replace those bumpers to reduce bottoming out but you have to remove the springs to install them so I opted to replace the springs and add new bumpers. I bought a pair of replacements from DCR (Jaguar XK8 and Jaguar XKR Parts and Accessories) that were copies of the originals at a much more reasonable price. BTW beware there is a difference between coupe and conv springs so make sure you specify. I have the coupe and ended up cutting 1-1/2 inches from the top and bottom runs of the springs which gave me a slightly aggressive ride height and no more bottoming out.
Old Jun 11, 2018 | 04:47 PM
baguafit's Avatar
Well, I think I may have figured the suspension fault mystery. The fault reappeared a few days ago along with an Electrical Fault. Upon looking at the shock connections, a sparkle caught my eye in the well of the top shock which holds the 2 wires. I got a flash light and could see some debris so put a tiny magnetized screwdriver in there and pulled out some fine metal shavings -- not much but they were long enough to cause a short between those two wires with each other or grounding out. My hunch is this was the source of my wild goose chase. Maybe too early to say for sure but at least this is a plausible cause.
Old Jun 11, 2018 | 07:07 PM
dgr's Avatar
dgr
Smile
Thanks baguafit. I'll get some ordered.
Old Jun 15, 2018 | 09:40 AM
  #28
Salo's Avatar
I am very interested in the solution of this fault - I also got suspension fault after patching into two wrong wires - so I now ordered a new control unit as I suspect this is what causes my fault. Once I replaced it I give You an update, still waiting for it to arrive..
original in XKR
used replacment module - all # match
Old Jun 27, 2018 | 06:31 AM
R3Wood's Avatar
Yikes. I'm putting all new coil springs, shocks, seats, mounts, boots, today. My hope is it's plug and play.
Old Apr 5, 2019 | 12:37 PM
  #30
baguafit's Avatar
And finally resolution...I hope So after I had the wires repaired and ~5000 miles of hassle free driving, Suspension Fault reappeared and diagnostic AGAIN indicated open circuit in right rear shock wiring harness. Having a pretty good guess as to what was wrong I went to a 2nd mechanic who pulled the wheel out and found the wires had again broken but in another place (not where previously repaired). Thinking the 1st mechanic must have did something wrong I paid my $800 and had it repaired again. Another 5k miles and another fault and diagnostic indicating the SAME problem!!! Finally figured out the bushing in shock mount was so warn that the shock was rotating slightly with every bump in the road causing the wires to wind. Replaced the bushing and repaired the wiring and hope I never have to post on this again!
Hope this is helpful to someone out there.
Old Feb 17, 2025 | 06:05 PM
  #31
MaxTorq's Avatar
hey,
i have a 2006 xkr coupe and the suspension fault has just come on 58k miles...
i have been monitoring the collapse of my front rubber mounts and they are flat now.
bottoming out of the front end on both sides.
i am hoping this caused the fault...we will see...
thank you for this thread and all the info.
i will be checking ALL this wiring while i am replacing the mounts.
i have new rubbers for the rear as well.
kind regards,
Max
RayR
Apr 22, 2023 01:15 AM
JaguarXKR
Aug 20, 2020 07:49 AM
ReidK
Nov 4, 2019 11:48 AM
StorminN
Oct 5, 2014 05:36 AM
embassured
Jan 2, 2009 12:02 AM
