Suspension Fault Warning
Old Jul 9, 2025 | 03:17 AM
Rocky15's Avatar
Default Suspension Fault Warning
I've just got a suspension fault warning on my 2000 model XKR. My basic code reader doesn't show up any faults. I've disconnected the battery and when reconnecting it the fault is still there.
Ant ideas what it could be would be appreciated.
Also when I disconnect the control box the fault is no longer there which I would expect.
Old Jul 9, 2025 | 03:51 AM
dibbit's Avatar
I think you can read the fault codes with IDS, but I'm not sure if any aftermarket scanners can read the module.
Simpler maybe is to get the wiring diagram for your car and measure the resistance to each shock at the CATS module connector. You likely have a broken wire to one of the shocks. Faults on the acceleration sensors will also trigger the warning, but start by checking the shocks and hope the problem is at the front of the car, not the back.
Old Jul 9, 2025 | 06:48 AM
JaagXKR's Avatar
Originally Posted by dibbit
"and hope the problem is at the front of the car, not the back."
Luckily (or not) 2000 model has only cats on the front shocks. You must read the fault codes, there are some generic scanners that works well, for example with my Icarsoft LR I can read all the codes.
Old Jul 9, 2025 | 09:42 AM
artntek's Avatar
Also make sure your battery is fully charged. If I leave mine off the trickle charger for a while, it’s usually phantom suspension faults that show up.
Old Jul 9, 2025 | 10:12 AM
Rocky15's Avatar
My car is always on charge
Old Jul 9, 2025 | 10:23 AM
giandanielxk8's Avatar
Are you sure about that?
Old Jul 9, 2025 | 05:46 PM
zray's Avatar
my also whenever it sits overnight or longer. Sounds like obsessive compulsive behavior, and likely is. But my electrical gremlins / issues vanished once the tender was installed.
I have the same OBD-II reader. It seems to always come up with a code whenever there’s a fault with a system. But does it read all codes ? I can’t answer that one .
Z
Old Jul 9, 2025 | 07:25 PM
Z
I was asking about not having rear-CATS shocks and only having front CATS shocks on the 2000 model year XKRs.
Old Jul 9, 2025 | 08:11 PM
motorcarman's Avatar
The CATS (Computer Active Technology Suspension) has active dampers on ALL FOUR CORNERS.
Old Jul 9, 2025 | 08:32 PM
baxtor's Avatar
There's one on each of the 4 corners of my 2000 XKR.
Old Jul 9, 2025 | 11:10 PM
zray's Avatar
People often change the CAT dampers for financial considerations. Maybe that’s why you are missing two of them.
Z
Old Jul 10, 2025 | 01:30 AM
JaagXKR's Avatar
I have never verified on my car, I have seen some videos where it is said that the first series had Cats only in the front, and I thought it was true.. I apologize. If I have them on all four it is better , as soon as possible I will check.
Old Jul 10, 2025 | 02:40 AM
dibbit's Avatar
If you feel like testing if it can read the CATS module, you could try unplugging one of the front dampers (the plug under the plastic dome) - you will get the SUSPENSION FAULT message on the dash and there should be a code available to read.
Old Jul 10, 2025 | 03:03 AM
Rocky15's Avatar
I've been told that's incorrect.CATS at front and back
Old Jul 10, 2025 | 03:05 AM
Rocky15's Avatar
I've been told front and back. You can also see this on Jag parts website
Old Jul 10, 2025 | 03:07 AM
Rocky15's Avatar
Thanks for the diagram. Do you know where the accelerometers are located
Old Jul 10, 2025 | 03:33 AM
dibbit's Avatar
The accelerometers are on the front and rear bulkheads and inside the ECU compartment in the engine bay (2, 3 and 6 in the photo) and are not easy to get to. When they fail, they usually just don't produce any output (or a limited output) rather than producing any kind of fault. You can test them with a multimeter at the module connector.
Start though with the shocks - almost certainly where you will find the fault and almost certainly it will be one of the rear ones you can't get to.
Old Jul 10, 2025 | 03:35 AM
baxtor's Avatar
Top 3 lines in screenshot.
Old Jul 10, 2025 | 12:43 PM
Yep, that's what I thought. It made no sense to me that the 2000 model year cars wouldn't have rear CATS shocks.
Z
If he is missing the rear ones, that would explain his Suspension Fault warning. I would check the rear CATS shock harness. It's apparently a little short and is can become damaged and produce a Suspension Fault warning.
Old Jul 10, 2025 | 01:11 PM
If the rear are deleted (replaced with standard dampers) then just replace the fronts also unless you want CATS.
CATS dampers are a bit pricey is why people just use the standard dampers.
Disconnect the module if the dampers are no longer CATS.
You should not disconnect the module if the fronts are still CATS and you don't want a 'terrible' ride.
