suspention
Old Aug 11, 2019 | 08:03 AM
ericdemol1958's Avatar
Default suspention
my xkr is too low at the front
Old Aug 11, 2019 | 08:21 AM
welcome to the forum - what year is your XKR? What is the mileage? A low front is most likely caused by worn upper shock mounts - check this by looking at area around upper shock bolts and you will see crumbling foam if shock mounts are bad. Other contributors are lower shock bushings and/or control arm bushings or worn springs or shocks. I would more than likely suspect the upper mounts as they disintegrate over time vice mileage
As this is your first post, please stop by the New member section and post an introduction. In return, you will receive a warm welcome along with useful tips to navigate the forum - enjoy
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Aug 11, 2019 | 07:30 PM
avern1's Avatar
Measure the distance between the center of the wheel to the top of the fender arch. It should be about 15.75 inches. If it is less the shock mount is probably bad.
Robert Leonardo
May 13, 2017 07:27 AM
NCC-1701
Sep 16, 2014 02:26 PM
the almiesta
XJ40 ( XJ81 )
Aug 6, 2010 05:59 PM
cancer63
XJ40 ( XJ81 )
Mar 7, 2010 07:39 AM
