Tail lights not working
Old Oct 22, 2012 | 12:40 PM
Charlie Galea's Avatar
Red face Tail lights not working
Hello again I am having a problem with my tail lights not coming on on my 2000 XK8. The fuses and relay are all ok and am getting power to relay pin 1 and 3. I opened the lamp module and found resistor R8 to be burnt. My question is should i chang the module or the resistor and if the resistor what type is it. I took some pics of the board but cannot seem to get them attached to this tread. BTW i still have the dash light still staying on after i switch everything off so if anyone has an idea about what is causing that i would appriciate it thanks.
Old Oct 22, 2012 | 10:39 PM
WhiteXKR's Avatar
The resistors are used to sense bulb failure. You can try to replace the resistor (if you have soldering skills) or the module, but it is possible there is a short in the circuit that caused the resistor failure. You should check for a short on the corresponding wires to the lamp socket that connect to R8 outside the module.
If you want to replace the resistor post a picture (see Jaguar Forums - Jaguar Enthusiasts Forum - FAQ: Reading and Posting Messages) or at least post the numbers and letters or colors and we can help you identify the value.
Old Oct 23, 2012 | 03:07 AM
Thanks WhiteXKR I will try and post some images on a seperate post
D.K
Dec 10, 2023 02:05 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
johnnie ryall
Oct 19, 2015 09:44 PM
Jandreu
Aug 29, 2015 07:31 PM
