TCM Location
Old Oct 23, 2017 | 02:34 PM
jbudnick's Avatar
Default TCM Location
Trying to find the physical location for the transmission control module on 97 XK8.
Old Oct 23, 2017 | 02:44 PM
brgjag's Avatar
in with the main computer, engine bay, nearest to firewall under the triangle like plastic cover with a hole in it. It is tight quarters in there but if I recall correctly the trans ecu comes out first. Be careful, take your time to pull it out (wires).
Old Oct 23, 2017 | 07:17 PM
RJ237's Avatar
Yes, and if you disconnect either remove the neg. battery cable from the battery first.
