Tensioner debris
Old May 23, 2015 | 10:20 AM
scoobie's Avatar
Default Tensioner debris
I pulled one of the cam covers and wasn't surprised to see a (presumably) old style tensioner there.
I will order the pair off ebay - there are a couple of traders doing a set for £75.
In the other photo you can see some debris.
I have vacuumed it out now (3 bits) but am wondering if they came off the secondary tensioners or somewhere else?
Old May 23, 2015 | 03:12 PM
RJ237's Avatar
Unfortunately, your second picture is not as clear, but I think it's looking down along the primary chain and may be parts if the guide.
If that is failing you need to remove the timing cover and replace the lower tensioners and chain guides, then drop the pan and get all the pieces out of the oil pickup screen.
Old May 23, 2015 | 06:10 PM
test point's Avatar
It looks like you may be missing the slipper off the tensioner pictured. If your chain is running on metal there is a significant amount of missing red plastic.
Old May 23, 2015 | 06:56 PM
RJ237's Avatar
Thanks Tom, I missed the obvious.
Old May 24, 2015 | 04:24 AM
scoobie's Avatar
Wow - a bullet dodged there!
Does the slipper breaking up destroy the chain or is it likely to have survived?
What should I look for?
Thanks - Mark
Old May 24, 2015 | 04:52 AM
test point's Avatar
The chain should be fine but this does justify removing the oil pan to clean the oil pick-up screen as RJ237 indicated.
boiler
US Southwest
Dec 20, 2025 12:38 AM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
