Thanks! Needing more help. Let's put all this things together!
Old Sep 27, 2017 | 07:09 AM
SirJohn's Avatar
Originally Posted by Rick L
The little black plug is for the tonneau cover. It covers the top when the top is down. There are 2 of them so there are 6 black rubber caps one on each end of 3 clear tubes about 2" long.
Excellent, do you know the name of the thing that goes between the black plugs? I have one missing. Tks!
Old Sep 27, 2017 | 07:13 AM
SirJohn's Avatar
Originally Posted by michaelh
Tow hook (I suppose strictly, towing eye) - there are two different threads: early M20 is part # HJA4333AC, M16 is C2C37723. Not sure when the change happened. Some have used a bolt and welded on an eye. Do a search here on 'towing eye' for some ideas.
The plastic tool for removing the wheel nut caps is MNA6265BA. The key might be harder to source; you can try the dealer but he might want to sell you a complete set of nuts along with the new key.
I've attached a couple of pictures showing the trunk lamp assembly. It's in two parts, both which you appear to have.
Good job on the repair btw
You was right, I have all the pieces. However, I put everything together, check if it was power (it is power) but still is not working. Which is kind of crazy, I have power then I put a lamp in the middle and it doesn't work...I bought a LED lamp, would that be a problem?
Old Sep 27, 2017 | 10:54 AM
michaelh's Avatar
Flip the lamp the other way round in the socket & try again. Most LEDs are polarity conscious.
Old Sep 27, 2017 | 11:05 AM
SirJohn's Avatar
Wow didn't know that. Thanks!
Old Sep 27, 2017 | 12:43 PM
DevonDavid's Avatar
Yes - it's called a "Plastic Tube" - part number HJA78945DA. About $3US I think. (£2.17 UK)
A couple of inches of ball-point pen tube for 5 cents will do the same job unless you are worried about originality !!
