Is there a better cup holder?
Old Sep 22, 2018 | 07:37 PM
engravosaurus's Avatar
Default Is there a better cup holder?
97 xk8 coupe
tech was leaning on the arm rest and pop, cup holder broke
so I have it out ready for fix or replace but I see lotsa complaints on the web about these xk8 cup holders
so before replacing with same
is there an after market cup holder that fits and is better built?
thank you
Old Sep 22, 2018 | 08:54 PM
150FHC's Avatar
I'll be interested to hear other answers but suggest that it's better to leave the drink holders broken and forget the idea. Mine were broken but still usable with a little fiddling, when I got my 2006 XJ8 coupe, two years ago. As soon as I tried to use them, I discovered that any drink placed therein was v much in the way and in danger of getting knocked over and spilled. Soon thereafter, I noticed coffee or Coke stains on the carpet on the other side of the console, where some previous driver had knocked over a drink or two.
I now keep a small bottle of water tucked behind the seatbelt buckle and have resigned myself to have no other beverages in my Jag.
Granville
Old Sep 22, 2018 | 10:18 PM
Agreed. The cup holders are poorly designed and manufactured. And certainly should not be used for tumblers.
But mine broke in such a way that if my arm leans at all on the arm rest, the cupholder falls out of place. So would like to fix it just to stop that.
if there is no "store bought" fix, I might try a home remedy. Some malleable plastic and glue.
In fact, a home remedy might be better.
pic shows broken out piece
pic shows the broken out piece of plastic which allows the shaft to fall out
Old Sep 23, 2018 | 02:48 AM
StuG's Avatar
Old Sep 23, 2018 | 10:22 PM
so the home remedy
New cup holder expensive. So...
Bought some heat malleable plastic and JB Weld Plastic Bonder
Used one piece to fill the gap, used a second to secure first in place.
Shaft did not dislocate to manual pressure but...
Will re-install and see what my elbow does.
Old Sep 24, 2018 | 03:50 AM
christ's Avatar
The first piece of advice I got after buying my X100 was regarding the cup holders. Even before the tensioners.
Cup holder often fails. When operational it works better to distribute contents of cup(s) over back seat before hand as that is where contents will end up when under heavy acceleration - this is normal. You can also dump it in your lap or the passengers lap if you plan to turn first. Either action saves a step and comes as less of a surprise.
Old Sep 24, 2018 | 11:52 AM
150FHC's Avatar
Brill!
Old Sep 26, 2018 | 09:45 AM
80sRule's Avatar
Most european cars I've owned; Mercedes, BMW, Audi, Jaguar, etc; have garbage cupholders. It appears they get too creative with swingout, popup, and other designs. My X150 XKR has better cupholders than the X100; but they still aren't great. Best I've ever had have been just cheap crap molded ones in a 97 Dodge Neon. They held cans, 20ozers, big gas station cups (44oz like) and NEVER had issues. It appears the Jaguar designed cupholders are like those old cupholders built into pickup truck glove boxes; they are ONLY for use when parked.
Old Sep 26, 2018 | 10:18 AM
Supersprint's Avatar
SAAB knew how to make a cup holder
Old Sep 26, 2018 | 02:42 PM
150FHC's Avatar
wow! Those are brilliant! Very impressive in minimalism in the few moving parts and the tiny amount of dash space required.
Granville
Old Sep 26, 2018 | 03:05 PM
rothwell's Avatar
Granville
Yeah. But its wrapped in a Saab.
Old Sep 26, 2018 | 03:07 PM
Gus's Avatar
Gus
See if this repair job helps.
Old Sep 29, 2018 | 01:58 PM
enderle's Avatar
Default Hot Rod Cup Holders
Originally Posted by engravosaurus
97 xk8 coupe
thank you
I got hot rod cup holders and had an upholstery shop put them in. Wasn't a cheap date (don't remember the cost) but the end result was better cup holders (work best with Starbucks cups) and a much more comfortable armrest. Horizontal Billet Aluminum Single Slide Out Beverage Holder | Santanainteriors.com
Cup Holders Open
Armrest side
Arm rest open (the switches are there because I also put in a double DIN radio)
Cup holders out open.
Cup holders fron of armrest closed.
Old Sep 29, 2018 | 02:05 PM
giandanielxk8's Avatar
Part of the problem with the cup holders is their location, the armrest. The other 2 problems are that they have a 2 inch gap to the sides through which the drinks can slide out of, and that the surface inside the cup holders is made of slippery plastic that does not provide any grip to the cups.
Old Mar 23, 2019 | 11:24 AM
Hi
6mo after repair in #5
Still has not popped out
Will call it a victory; take joy where I find it
Old Mar 24, 2019 | 12:27 PM
Terrific's Avatar
I posted on the cup holder I fabricated on 9-5-2017,titled cup holder, by Thomasso. May not be your cup of tea,but works for me. Originals are junk, even if not broken they wont hold most cups
Old Mar 24, 2019 | 12:31 PM
Link to the thread?
Old Mar 24, 2019 | 08:56 PM
Terrific's Avatar
I guess I don;t know how show a link, Its on page 15 of Cup Holder posts
Old Mar 24, 2019 | 09:08 PM
Hi
Link is https://www.jaguarforums.com/forum/x...holder-188730/
is nice cup holder
but I wanted to stop mine from popping out when my elbow hit it so had to
1) ignore
2) buy new one
3) fix
the fix method as in #5 has worked for 6 mo; but was a pain; buy new one might have been better
Old Mar 24, 2019 | 10:09 PM
Hi
is nice cup holder
1) ignore
2) buy new one
3) fix
Wow, that is an interesting solution. Mine so far has been: drive the Jeep if I must have a drink, or not take a drink on the car with me.
afterburner1
Sep 22, 2021 08:24 AM
THELARRIKIN
Apr 25, 2013 12:09 PM
taxman33
Mar 6, 2013 04:28 PM
scchuck
Oct 15, 2006 12:15 PM
