Is there a trick to getting valve keepers in position 2001 XK8 cylinder Head
Old May 13, 2015 | 02:27 PM
seventhjag's Avatar
Default Is there a trick to getting valve keepers in position 2001 XK8 cylinder Head
I am finding it very difficult to get the two very small valve keepers in position
to release the valve spring compressor to seat keepers after replacing valve in cylinder head . IS THERE A TRICK TO DOING THIS ? 2001 jAGUAR xk8 4.0
Old May 13, 2015 | 07:14 PM
motorcarman's Avatar
A non-magnetic hemostat, a plastic or stainless steel probe, a steady hand, maybe a dab of grease and a lot of patience!!!!!!!!!!!!!!!!!!!
good luck, been there!!
bob gauff
Old May 13, 2015 | 09:36 PM
Mvirgil's Avatar
Are you using a hand held compressor? the task will be very difficult. As motorcarman said a little bit of grease and alot of patience. If you knocking the keepers off because the retainer moves crooked, i would try and find a proper screw adapter for the valve face (i have seen some rubber ones that work well) to ensure the tool stays parallel to the valve stem. Personally i would not attempt instillation with a hand help compressor; i worked some time in a machine shop and we had a pneumatic cylinder head bench making instillation a breeze. if you have a automotive machine shop nearby i doubt they would charge you much of anything just for the instillation.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
Bowman
Sep 3, 2015 03:17 PM
