Are these chips enough to ruin this reluctor ring
Old Aug 5, 2025 | 11:19 AM
Schrodinger's Cat's Avatar
Default Are these chips enough to ruin this reluctor ring
If you look closely, you will notice that two of the teeth on this reluctor wheel are chipped. I get no reading from this wheel. I have swapped the wheel speed sensors and the problem remains on this wheel. I have tested the wire for continuity from the sensor all the way to the ABS module-all good.
this is a 2003 XKR 4.2 Supercharged.
If you look closely, you will notice that two of the teeth on this reluctor ring are chipped. I get no reading from this wheel. I have swapped the wheel speed sensors and the problem remains on this wheel. I have tested the wire for continuity from the sensor all the way to the ABS module - all good.
This problem appeared when I changed the front strut top mounts. The problem, at this point, must be with this ring or the ABS module, and I can’t see how changing out the strut mount could have damaged the module.
Old Aug 5, 2025 | 11:53 AM
RJ237's Avatar
Connect your ohm meter to the sensor and rotate the wheel. you should see a change in resistance for each notch.
Old Aug 5, 2025 | 12:26 PM
Default I’ve heard that I can try voltage from the sensor while turning the wheel,
…but it is only supposed to put out .5 to 1 volt. My multimeter doesn’t read AC voltage that low.
What should the readings be when testing ohms?
Old Aug 5, 2025 | 01:21 PM
89 Jacobra's Avatar
Active Streak: 30 Days
I don't know the ohm reading but it should fluctuate back and forth, as in, on off on off on off. Maybe someone knows the values??? Hope it helps
Jack
Old Aug 5, 2025 | 03:52 PM
RJ237's Avatar
Don't worry about the actual resistance, just confirm that it fluctuates. It may be 1K ohms
gmcgough
Jun 22, 2024 05:57 PM
cdma
Sep 19, 2021 03:42 PM
max224
Jul 23, 2020 10:30 AM
icey
Feb 15, 2018 10:27 PM
mrobinson
Jul 20, 2015 07:46 AM
