Think I've killed my XK8!
Old Jan 21, 2025 | 03:35 AM
RichardS's Avatar
Originally Posted by martinbee
Hi again, thanks for all the replies and suggestions. One more question!! The gear-lever is stuck in park and will only move back about three quarters of the way to reverse when I put a screwdriver in the release hole (foot on brake). Any suggestions?
Presumably when you do do put the screwdriver in the release hole, the lever does not move more than a few mms?
If that is the case it sounds like something is sticking. The first thing I would try is to get someone to rock the car backwards and forwards a few inches whilst you are trying to engage reverse and see if that frees something up.
If that doesn't work you'll need to remove the gearbox cowling to access the solenoid engagement mechanism. The four hidden clips are a bit fiddly so don't try to force it but look for full release details on line.
Richard
99xk8guy
May 28, 2024 09:36 PM
dazer2000
May 8, 2015 12:58 PM
mctb
Jun 1, 2014 11:19 AM
Martin
Mar 2, 2014 06:33 PM
thoge
Mar 10, 2008 12:53 PM
