Throttle body manufacturer
Old Jul 11, 2012 | 11:46 AM
MRomanik's Avatar
Veteran: Air Force
Default Throttle body manufacturer
Anyone know who makes the throttle body?
I found a basic fuel injection pump tester but it will not work on Bosch,CIS Jetronic, and GM Throttle body system.
heres the link
Fuel Pressure Tester & Fuel Injection Pump Tester
Last edited by GGG; Jul 11, 2012 at 06:01 PM. Reason: edit typo in thread title so it appears in searches
Old Jul 11, 2012 | 12:02 PM
Jochem00's Avatar
Motorcraft,
But I do not see the relation between the two.
Old Jul 11, 2012 | 03:28 PM
MRomanik's Avatar
Veteran: Air Force
If ours was made by Bosch,for example, I would not purchase the testor.
Old Jul 11, 2012 | 04:24 PM
Beav's Avatar
If your car is equipped with a Schrader style port on the fuel rail that tester should fit - pretty standard stuff. The reason for the exclusions you mentioned are they require banjo fittings and/or other adapters in order to connect. At <$20 I'd question the accuracy of the gauge - if you were just comparing pressure drops by means of an injector pulsator it would work. But, for the sake of argument, you have one of the many GM vehicles that absolutely will not start when the fuel pressure is below 53# and the gauge reads 49# don't be surprised if the fuel pump was not the culprit...
Old Jul 11, 2012 | 10:03 PM
MRomanik's Avatar
Veteran: Air Force
Thanks.
I'm a shadetree mechanic & want to use it on my Jags - 97 XK8 & 07 X Type.
I do wonder about the accuracy & quality though.
Old Jul 12, 2012 | 07:58 AM
motorcarman's Avatar
You have a DENSO system and that should work just fine.
bob gauff
xjrjag
Oct 24, 2024 03:09 PM
GGabriel
Nov 22, 2018 03:53 AM
Stilling
Oct 5, 2015 04:23 PM
thedugger1
Sep 26, 2015 10:27 PM
BSM
Sep 25, 2015 05:00 PM
