Throttle Position Sensor Plug Wires
Old Apr 30, 2021 | 05:14 PM
conceptoys's Avatar
Default Throttle Position Sensor Plug Wires
Hello all, I have a problem.
While putting in a new rear main seal I apparently knocked 3 of the 4 wires out of the TPS plug, only the black/green wire is still attached.
The wiring diagram in my service manual shows the black/green wire is pin 3, but it is pin 1 in my car, so I can't trust the book.
The wires I have are blue/white, blue, green, and black/green. The plug goes into the TPS vertically.
Could anyone please let me know the correct order of the 4 wires from top to bottom?
Thank you for any assistance.
Old May 1, 2021 | 02:47 AM
dibbit's Avatar
What car and year? My wiring diagram for a 2001 shows:-
1 BG
2 G
3 N
4 OY
Old May 1, 2021 | 05:37 AM
conceptoys's Avatar
1 BG
2 G
3 N
4 OY
Oops, sorry. This is my first post.
I have a '97 XK8.
I hear they changed quite a bit by 2001.
Thank you for trying.
Old May 1, 2021 | 08:09 AM
michaelh's Avatar
Here's a snippet from the 97 Electrical Guide, which shows
4 UW
3 U
2 G
1 BG
so your pin #3 #1 is in agreement with the above. Note, however the caveat re cars with VIN last 6 <= 003300
My 98 has the same TB and also concurs with the above:- pin numbering seems to be bottom to top.
edit: correct pin reference, doh!
Old May 1, 2021 | 11:11 AM
conceptoys's Avatar
Thank you Michael!
That's the picture I have in my manual as well, but didn't realize what the -numbers meant.
I should have it back together soon, thank you again!!
Silvius
Oct 31, 2020 11:21 PM
James O
Jun 11, 2016 09:04 PM
louvit
Feb 12, 2016 10:33 AM
wr51
Mar 7, 2015 03:45 PM
chrismc50
Jun 29, 2014 08:20 PM
